Transfer case leak
2003 FORD EXPLORER
150,000 MILES • 4.6L • V6 • 4WD • AUTOMATIC
NICOLE8468
Pulling out of my driveway I noticed fluid. It is a dark brownish color. I looked under the vehicle and could see that the drive shaft was all wet. After I drove it I turned it off and noticed a burned smell that smelled just like asphalt. The truck seems to run and drive fine.
Aug 6, 2017 at 3:18 PM
It sounds like you have a rear seal leaking from the transfer case. Grab a flashlight to look under the car to confirm. If so here is a guide to remove the drive shaft so you can replace the seal.
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
Let me know if that is what it is and I will send instructions on how to change it.
Please let us know what you find.
Aug 7, 2017 at 3:51 PM
