LED rear blinkers
2019 HONDA INSIGHT HYBRID
25,672 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
NATE DUNCAN
  • 16 POSTS
Would you know if these LED blinkers would work in the 2019 Honda insight hybrid and If so what size of the bulbs and will they even work in my vehicle?
Sep 29, 2019 at 10:08 AM
It says the bulbs are already LED. Here are the part numbers and instructions on how to change the brake light and running light bulbs which show the LED's:
12v16w - 33506S8RN51 $5.68
12v21w Amber - 33303SCK003 $6.23
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response. Check out the diagrams (below). Please let us know what happens.
Sep 30, 2019 at 7:19 PM
NATE DUNCAN
  • 16 POSTS
My video.
Oct 1, 2019 at 5:18 PM
Thanks for the video. Okay I see, yep lets try the LED rear bulbs to see whats happens. Please send a new video once the bulbs are installed. I am interested to see what happens.
Oct 2, 2019 at 10:47 AM
NATE DUNCAN
  • 16 POSTS
What size of bulbs do I need and to do the ones from the Amazon link that I sent you work?
Oct 2, 2019 at 10:48 AM
Yes they look like they will work. Let me know how it goes.
Oct 3, 2019 at 11:16 AM
NATE DUNCAN
  • 16 POSTS
Which size of bulbs do I need? They only offer 3 sizes.
Oct 4, 2019 at 1:36 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Have you removed the original bulb to see what the stamped number is on it ?
Danny
Oct 7, 2019 at 4:49 PM
NATE DUNCAN
  • 16 POSTS
No not yet. I should do that.
Oct 7, 2019 at 4:58 PM
DANNY L
  • 5,648 POSTS
Hello again.
Here is an image below on the taillight assembly removal. When you remove the bulb give me the number and I can cross reference you an LED bulb number.Thanks again for using 2CarPros.
Danny-
Oct 7, 2019 at 6:54 PM
NATE DUNCAN
  • 16 POSTS
Hey there, sorry i am taking so long to respond, but i have taken the bulb out of my vehicle and it appears to be this size. i took two photos. could you see if there is any LED turn signal bulbs i can use to replace these normal bulbs that i currently have?
Dec 15, 2019 at 4:21 PM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, here is what I found out. Your bulb for the rear blinker is based off the part number 7440A . Sylvania does make an LED bulb available at any parts stores. I've attached the stock bulb and the LED bulb below. If you want to go off Ebay or Amazon like the pictures you included then you will have to base it of the bulb number 7440A as I stated . Hope this helps and thanks gain for using 2CarPros.
Dec 15, 2019 at 6:50 PM
NATE DUNCAN
  • 16 POSTS
Hey there, so I installed these LED blinkers but they make my blinkers blink too fast? Do I need a resistor or something? I don't know what to do.
Dec 16, 2019 at 11:52 AM
We are going to need to experiment a bit with the resistance to get the computer to blink at the correct rate. lets try a 5 ohm first to see how must it changes. Please let us know what happens.
Dec 16, 2019 at 12:55 PM
NATE DUNCAN
  • 16 POSTS
5 ohm resistor?
Dec 16, 2019 at 2:03 PM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, whenever you install LED's you will have to change the turn signal flasher to be LED compatible . Sometimes like in your situation if not it will make them flash too fast. I will look up the NOVITA flasher part number for you.Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 16, 2019 at 8:12 PM
NATE DUNCAN
  • 16 POSTS
Thanks Danny!
Dec 17, 2019 at 8:04 AM
DANNY L
  • 5,648 POSTS
Hello again.
Just found out that your flasher is built into the BCM (body control module) So you shouldn't replace it that way. Sylvania makes a load equalizer to solve your problem.They are available at AutoZone, Napa, etc., as well as online.They run about $15.00. You can Google the name and it shows a YouTube video on how to install. I've attached a picture below.Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 18, 2019 at 1:56 PM
