1990 Lexus LS 400
1990 LEXUS LS 400
AZSEALE
Engine Performance problem
1990 Lexus LS 400 V8 Automatic 185000 miles
When I press the excellerater the car does not response at much slower response. There was smoke underneath the hood. The engine guage was normal.
Jan 9, 2010 at 9:17 PM
Check and test the following below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Cap and Rotor
Jan 10, 2010 at 3:48 AM
