The headlight on the left side dims after you initially turn on your lights as does the marker light. The left turn signal has malfunctioned and only works periodically or whenever it feels like it. There is no rhyme or reason to it working or not. Adjusting the steering wheel height, fiddling with it, nor percussive maintenance (hitting it) solves it. Fuses are fine. Replaced the bulbs. Hazard lights work perfectly and so do all the light on the right side of the vehicle.
The dealer said the Hyundai dealer replaced the steering column before we bought it.
Not sure if this matter or not but the locks can only be used while vehicle is running and interior lights do not work when ignition is set to accessories.
Locks and interior lights I can manage without but I do need my turn signal.
Any ideas on what could be causing this?
Jul 18, 2019 at 5:20 PM
