Changed fuse j10 P25 as suggested, no change. new battery still runs down with new alternator.
Ihave radio no power, fuse is good, engine idles up and down. Rear view mirror is removed and electric circuit is unplugged to this appliance. Also cd changer is disconnected. does this make a difference? Where do I look for charging problem now?
updated 10-26-09
Thank you for your response, however I am unable to read the diagram you sent. It is too small. Also when you say disconnect the harness, there are two plug in type harnesses at the alternator. Which one do I disconnect and them to test the wire would that be at the harness side or at the alternator pins?
updated 10-26-09
Oct 23, 2009 at 2:41 PM
