Crankshaft sensor location
2009 KIA SPORTAGE
213,000 MILES • 4 CYL • 2WD • MANUAL
KIA2009GIRL
Need to know where the crankshaft sensor is located.
Jan 8, 2019 at 11:07 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Jan 8, 2019 at 12:45 PM
JOHN HANSELMAN
  • 4 POSTS
code came up bad sensor.
Mar 26, 2021 at 10:37 AM (Merged)
CARADIODOC
  • 34,308 POSTS
That is not a common question from a mechanic unless there is some other underlying problem, but you did not include any details, so I will just add a couple of tidbits of value.
The sensor is slid into a hole, then it is held in place by a singe bolt. Remove the bolt, unplug the connector, then slide the sensor out.
Be aware diagnostic fault codes never ever say to replace parts. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. When a part is referenced in a fault code, that part is actually the cause of that code about half of the time. First we rule out wiring and connector terminal problems before we spend our customer's money on a part.
JOHN HANSELMAN
  • 4 POSTS
need to find location to replace.
LOU P
  • 118 POSTS
Here are two pictures from the service manual.
SARAGOMEZ
I cannot locate the crankshaft sensor on my vehicle. Help!
Welcome to 2CarPros.
I'm not sure if you have a 2.7L V6 or a 2.0L 4 cylinder. You listed two different things above. LOL
So, if you have the V6. you need to remove the fresh air duct under the hood. Once removed, the sensor is mounted on the engine. See pictures 1 and 2.
On the 4 cylinder, it is located near the oil pressure switch on the engine. See picture 3
Let me know if this helps.
JUNIOR64
  • 43 POSTS
Hi i would like to know where is the crankshaft and camshaft position sensor locate for 2000 kia sportage 2.0 and is that easy to replacing that sensor.
Camshaft position located at rear of cylinder head. Crankshaft position sensor, located at lower left side of engine in the transmission bell housing.
Here is a guide to help you step by step when changing the sensor out with diagrams below to show you on your car.
Both sensors are bolted on with one bolt and replacement is simple, only problem could be accessing them due to location. You might need to jack the car up
Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers
MAX29LOVE
Please tell me where the location of the sensor is and how hard it is to take it off and replace it how many hours does it show.
The book calls for .7 hours so figure around 40 minutes for replacement. The component is located in the left Rear of engine compartment (Transmission Housing). See picture 1. There is only one bolt that holds it in place. Here are the directions for replacement:
REMOVAL AND INSTALLATION
Removal
1. Disconnect negative battery cable.
2. Raise vehicle and support.
3. Disconnect wire connector from sensor.
4. Remove sensor mounting bolt.
5. Remove sensor from transmission cover.
Installation
1. Install crankshaft position sensor to transmission cover.
2. Install and tighten sensor mounting bolt.
3. Connect wire connector to sensor.
4. Lower vehicle.
5. Connect negative battery cable.
Here is a link that shows in general how to replace one. It includes pictures which you may find helpful.
Let me know if this helps or if you have questions. Also, I don't know what is happening, but here is a link that describes symptoms related to a bad sensor.
NICOLE GRIBBLE
How do I install a crankshaft position sensor on a 1998 Kia Sportage? Not sure where it goes...
Mar 26, 2021 at 10:40 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
Here is a guide that will give you an idea of what you are in for when doing the job with the location of the sensor rear the rear of the engine. https://www.2carpros.com/articles/crankshaft-angle-sensor-replacement Here is the location for your car https://www.2carpros.com/images/external/78720253.jpg Please let us know if you need anything else to get the problem fixed. Cheers
RAYDYE
Help, my wifes sportage has the single overhead cam 4cyl and I'm being told that it has a cam sensor that I can locate and a crankshaft sensor that I can't. I've looked at the back of the motor (between the firewall and the intake) and even traced all the wires to the back of the motor there isn't one to be found! I was told it was small but wouldn't it be wired (no loose wires hanging anywhere either)?
MERLIN2021
  • 17,250 POSTS
The crankshaft position sensor is located on the lower left of the engine here is a guide to help walk you through the steps and the location of the sensor in the diagrams below.
