Low power to fuses in fuse box?
2008 VOLKSWAGEN GTI
90,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
ABDUL REHMAN2
Hi, I am getting low power to fuses F6, F9, F10, F11, F12. Which is causing my car to run rough and getting fuel pressure regulator codes and evap codes. How can I diagnose and fix this?
Aug 23, 2023 at 1:06 PM
I would replace the engine compartment power supply relay, here is the location. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 24, 2023 at 12:07 PM
