Mass air flow sensor?
2007 GMC SIERRA
175,700 MILES • 4.8L • V8 • 2WD • AUTOMATIC
DGRS4LYF
  • 4 POSTS
Check engine and traction control lights came on and my truck would “jump into 2nd gear. Air intake code came up so I replaced mass airflow sensor. Truck no longer jumped but check engine and traction control lights stayed on. New code says it’s the air intake temperature sensor. Truck runs fine. Just the check engine and traction control lights are still on as well as air temperature code. I got the MAF from O'reilly auto parts and went for the cheapest one. Could it hopefully just be cheap parts or something more sinister? I’m not a mechanic but replacing MAF is simple enough to do myself. Thanks...
Feb 20, 2021 at 9:53 AM
It sounds like the sensor is no good because the air temperature sensor is inside the MAF sensor. I would make sure it is installed correctly and if so get an ACDelco unit from Amazon or Rock Auto. Check out the diagrams (below). Please let us know what happens.
Feb 21, 2021 at 10:12 AM
DGRS4LYF
  • 4 POSTS
Thank you! Going to order the whole unit now. Fingers crossed that will fix check engine and traction control lights.
Feb 21, 2021 at 4:28 PM
Please let us know.
Feb 25, 2021 at 8:04 AM
DGRS4LYF
  • 4 POSTS
Thank you! I put in MAF myself, with my 13 speed KW mechanic watching me, and all lights back to normal. Thank you! Best to buy the correct part/manufacturers item than going cheap route.
Mar 5, 2021 at 12:44 PM
Happy to hear it's fixed. Please feel free to come back anytime in the future. You're always welcome here.
Take care and God Bless,
Mar 8, 2021 at 7:01 PM
