location of map sensor
2000 MAZDA MPV
ANYWIREOFTN
Computer problem 6 cyl Front Wheel Drive Automatic 200000 miles
Where is the map sensor located can you tell me please? I love this site
Apr 9, 2010 at 1:51 PM
Your car has a mass air flow sensor not a MAP sensor. The MAF is located at the throttle body at the front of the intake manifold. Here is a guide to help you get the part replaced.
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
Here is a diagram to show you the location (below)
Nov 26, 2017 at 9:15 PM
MIDNITECOWBOY66
Electrical problem
2000 Mazda MPV 6 cyl Front Wheel Drive 126000 miles
I want to know the location of the map sensor.
Nov 26, 2017 at 9:16 PM (Merged)
FISHERMAN
  • 937 POSTS
[quote:7b23fcf5b6="MidniteCowboy66"]Electrical problem
I want to know the location of the map sensor.[/quote:7b23fcf5b6]
Hello !!
The MPV doesn`t use map Sensor...
I think it uses MAF Sensor..
What is your car problem?
Symptoms?
Let us know!
We will be happy to assist you!
RGONZALEZ2380
My pocket coder said it was the map sensor.
KOOLBEANS22`
  • 5 POSTS
want crank will turn over, short in the mapping sensor?? where is the pressure sensor located?
KHLOW2008
  • 41,814 POSTS
What have you done and check so far?
Have you checked for ignition sparks and/or fuel pressure?
What pressure sensor are you referring to?
