The problem started when I noticed a slight miss at idle that would disappear at 1000 rpm and up.Shortly after, the vehicle would barely run. It appeared to be running on only 2 cylinders and would only go about 30 mph. I changed the plugs, new wires, new cap and rotor, and a new battery. After that the vehicle failed to start. I'm getting spark at the plug and off the coil. I'm getting gas from the filter to the injectors. I checked the firing order and did a cold compression check (since engine won't start) and get between 150-170 lbs. The plugs appear to be wet with gas, yet won't fire. I changed the plugs from autolite to NGK with negative results. I checked ECM and discovered a burnt spot. I sent the ECM to Texas and had it upgraded and repaired. They test the unit by installing it in a vehicle and letting it run.
I'm at a total loss! I'm not sure if a sensor could be causing the problem. Could a mass air flow sensor, throttle position sensor, or oxygen sensor cause the vehicle not to start or even sputter? Could it be a crank or cam angle sensor. Does my year and model have these sensors. Your help would be deeply appreciated.
Thanks,
Steve
Thanks,
Steve
Feb 7, 2008 at 11:45 AM
