2002 Mercury Mountaineer brakes+rotor
2002 MERCURY MOUNTAINEER
111,000 MILES • V8 • AWD • AUTOMATIC
LOLOBABY328
how much would a repair (labor + parts) cost for all brake pads and rotors?
Aug 25, 2009 at 6:32 PM
RICKMAR
  • 170 POSTS
Complete brake job with pads,rotors,labor "all four wheels" with "good quality" parts will cost you somewhere in the vicinity of $450.
The rotors are the "Major"cause of the big cost.
If you can have your rotors resurfaced and the rotor thickness is within acceptable limits after resurfacing the cost will be a "LOT" less.
Usually the rotors can be resurfaced. It is a very common procedure
Rotors that are "deeply" gouged or have heat cracks are the cause of needing new rotors.
Good Luck;
Rick
Nov 18, 2009 at 10:07 PM
