Codes p0300 and p0302, misfiring, RPM's fluctuations on cold start
2010 GMC ACADIA
78,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
DRFIROJTADAVI
  • 33 POSTS
Misfiring since 6 months with RPM's fluctuations on cold start only. mechanic told me is due to oil leaking in cylinder, needs to change valve cover and sealing. how to confirm it (replaced spark plug, ignition coil, fuel injectors, previously)?
Dec 13, 2020 at 9:08 PM
On this engine, each cylinder has its own ignition coil. What can happens is where the coils go down through the valve cover, there is a tube that has seals on it. If the seals fail, oil can then leak into the spark plug tube that the coil is mounted to. If that happens, it can cause a misfire by causing the rubber boot on the coil to fail and short.
The easiest thing to do is remove the coil packs and inspect for oil on them.
If you look at the attached pic, it shows where the coil goes down through the valve cover to connect to the spark plug. That is where I feel the leak may be located.
I noted that you indicated cylinder 3 (P0302) has the misfire. If you look at pic 2, I highlighted the number 2 coil pack. Facing the front of the vehicle, it will be on your right.
Let me know if you have other questions or need help.
Dec 14, 2020 at 7:36 PM
DRFIROJTADAVI
  • 33 POSTS
Thanks for reply. i saw little oil in plug well.
Dec 15, 2020 at 1:27 AM
DRFIROJTADAVI
  • 33 POSTS
All spark plug tube seals are change with new spark plug on Monday, but today again check engine light came on with codes P302, P304 and P306. attaching freeze frame report if you see that coolant temperature 31 degrees C , and intake air temperature 25, Run time since engine start is 25 seconds.
Dec 16, 2020 at 1:10 PM
The fuel trims are a bit high (indicate the computer is removing fuel). But, they are not completely out of spec. I have a question. I'm not familiar with your scan tool. What is the fuel pressure?
The next thing I find of interest is that the new codes indicate misfires all on the same bank or side of the engine. It could be related to a fuel balance issue or pressure issue. Let me know if you have checked and what the pressure is in PS!. If I'm reading the scanner correctly, it's nearly 1500psi, which would blow the system apart. If you look at the attached pic, it shows what pressure should be.
Also, in your second pic, it shows long term fuel trims as really high. Bank 2 (where cylinders 2, 4' and 6 are located, it is excessive. The system is extremely rich. We need to check fuel pressure.
Follow the attached link above and let me know what you find.
Dec 16, 2020 at 2:03 PM
DRFIROJTADAVI
  • 33 POSTS
Thanks for input. this car is direct injection system so that having two fuel pressure system one is low pressure (fuel pump) and high pressure (seats on camshaft). so i have checked fuel pressure key on and engine of is 58-64 PSI.
Dec 16, 2020 at 8:30 PM
Okay, that is within spec. Did you try switching the coil from cylinder 2 with a different one to see if the misfire chances cylinders?
Dec 17, 2020 at 7:56 PM
DRFIROJTADAVI
  • 33 POSTS
I did swap the ignition coil from non misfiring cylinders to misfiring cylinder and change the spark plugs too. but misfiring didn’t change.
Dec 17, 2020 at 9:49 PM
Okay, if you still have the same problem, I'm starting to question if it is a fuel injector issue. If possible, follow this link and let me know the results:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Dec 18, 2020 at 11:12 PM
DRFIROJTADAVI
  • 33 POSTS
I am able to check only the injectors winding test which is within specification. rest test i cannot perform because i have to remove the TB and upper manifold with another parts to disconnect.
Dec 19, 2020 at 4:15 AM
I understand. I was thinking something could be causing it to stick open. As far as further diagnosis, the next thing would be to check engine compression. If the cylinder is low, that also can cause a misfire.
I'm sorry. I feel like I just keep adding more to do, but I'm trying to touch on all the things that can cause the misfire. If it isn't ignition and seems limited to one specific cylinder, then it leads me to believe it is fuel related or a compression issue.
If you can, here is a link that shows how to test compression in general:
Here are the manufacturer's directions which include the specs:
__________________________
2010 GMC Truck Acadia AWD V6-3.6L
Engine Compression
Vehicle Powertrain Management Tune-up and Engine Performance Checks Compression Check Testing and Inspection Component Tests and General Diagnostics Engine Compression
ENGINE COMPRESSION
Engine Compression Test
Tools Required
J 39313 Spark Plug Port Adapter
A compression pressure test of the engine cylinders determines the condition of the rings, the valves and the head gasket.
1. Run the engine until it reaches normal operating temperature. The battery must be at or near full charge.
2. Turn the engine OFF.
Important: Remove the powertrain control module (PCM) and the ignition fuse from the instrument panel (I/P) fuse block.
3. Disable the ignition.
4. Disable the fuel systems.
5. Remove the spark plugs from all cylinders.
6. Remove the air duct from the throttle body.
7. Block the throttle plate in open position.
8. Measure the engine compression, using the following procedure:
1. Thread the J 39313 into the spark plug hole.
2. Thread the compression gage into the J 39313.
3. Have an assistant crank the engine through, at least 4 compression strokes, in the testing cylinder.
4. Check and record the readings on the gage at each stroke.
5. Remove the compression gage from the J 39313.
6. Remove the J 39313 from the spark plug hole.
7. Repeat the compression test for each cylinder.
9. Record the compression readings from all of the cylinders.
* The lowest reading should not be less than 70 percent of the highest reading.
* No cylinder reading should be less than 965 kPa (140 psi).
10. The following are examples of measurement problems:
* When the compression measurement is normal, the compression builds up quickly and evenly to specified compression on each cylinder.
* When low compression is caused by the piston rings, compression is low on the first stroke and tends to build up on the following strokes, but does not reach normal. Compression improves considerably with the addition of oil. Use approximately 3 squirts of oil from a plunger-type oiler.
* When low compression is caused by the valves, the measurement is low on the first stroke and does not build up even with the addition of oil.
* Leaking head gaskets will provide the same results as worn valves but engine coolant may be identified in the crankcase. In addition, a leaking head gasket will give low readings on paired cylinders.
11. Remove the block from the throttle plate.
12. Install the air duct to the throttle body.
13. Install the spark plugs.
14. Install the powertrain control module (PCM).
15. Install the ignition fuses to the I/P fuse block.
___________________________________________
Let me know if you are comfortable doing this.
Dec 19, 2020 at 2:40 PM
DRFIROJTADAVI
  • 33 POSTS
I let you know about compression test. i have question that car runs 78,000 Km can it loose the compression as i heard from mechanic usually high mileage engine having problems regarding compression.
Dec 20, 2020 at 12:03 AM
To be honest, it would be odd. However, it is really based on how the vehicle was maintained. Other than that, we need to check the injectors.
Dec 20, 2020 at 7:51 PM
DRFIROJTADAVI
  • 33 POSTS
Yes sir, i will let you know.
Dec 20, 2020 at 7:55 PM
DRFIROJTADAVI
  • 33 POSTS
Hi, replaced the valve cover gasket and did the compression test for all cylinder was 140-150 PSI. Transmission can cause cold engine start misfire? and also found out the this attached image, is going to causes the misfiring.
Jan 1, 2021 at 7:53 PM
There is a lot of carbon. However, if that was causing the valve not to seal, it would have been evident with the compression test. I will tell you that 140 is what they indicate compression should not be lower than. Just for curiosity, were the cylinders at 140 the ones that have the misfire issue?
Also, and I may have already asked if you have a live data scan tool, have you checked the signal from the engine coolant temp sensor? (ECT see pic 1) Also, have you confirmed there are no engine vacuum leaks when it's cold?
Jan 2, 2021 at 12:03 AM
DRFIROJTADAVI
  • 33 POSTS
Initially suspected vacuum leaks. so did smoke test with homemade smoke machine but it doesn’t help. might be not accurately done. yes, i will send you live data of coolant temperature. the compression for misfiring cylinder was 141 PSI.
Jan 2, 2021 at 12:56 AM
At this point, what I would have to watch live data to determine if it is actually an ignition issue or mechanical issue.
Based on the compression, the work you have done, no vacuum leaks, fuel pressure within spec, and the fuel injection is working, that leaves the possibility of a weak valve spring or if the carbon is causing issues on and off. I would think it would have to be related to a mechanical issue.
Also, if it was a sensor, I don't see why it would affect cylinder 2. By chance, have you been able to check the fuel injector?
Let me know. Also, I will be having surgery tomorrow (Monday). Please hang in there and I'll get back to you as soon as I can. If it is more than a day or two, Ken, the site owner, will likely get back to you.
Jan 3, 2021 at 6:07 PM
DRFIROJTADAVI
  • 33 POSTS
Oh, okay. wishing you speedy recovery .
Jan 3, 2021 at 10:24 PM
I have seen a bad MAF sensor cause the misfire issue without throwing a code, also I would service the throttle bore. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
and
After the work please clear the codes.
https://youtu.be/ahK_eucFi-k
Jan 6, 2021 at 11:12 AM
DRFIROJTADAVI
  • 33 POSTS
Live data signal of coolant temperature sensor, if can notice the how the RPMs fluctuate
Jan 6, 2021 at 12:10 PM
DRFIROJTADAVI
  • 33 POSTS
Today check engine light came on and having code p300 and p304. As previously it was P302 constantly for last 6 months.
Jan 6, 2021 at 7:08 PM
yes, did you service the throttle bore? also we should check for a vacuum leak. this guide can help:
if no leak I would get a new MAF sensor as well.
Jan 7, 2021 at 11:25 AM
DRFIROJTADAVI
  • 33 POSTS
I will check vacuum leaks again. i have replaced the throttle body and MAF sensor before this problem approximately 2 months before still do i need to replace it?
Jan 7, 2021 at 11:44 AM
not really, i am leaning toward the vacuum leak.
Jan 7, 2021 at 12:10 PM
DRFIROJTADAVI
  • 33 POSTS
Okay, i will let you know.
Jan 7, 2021 at 12:23 PM
DRFIROJTADAVI
  • 33 POSTS
At cold start when misfiring and RPM fluctuations occurring the advance timing for cylinder number 1 is negative (retarded) 13-15 degrees , when the advanced timing becomes positive around 5-10 degrees the rpm stabilise. is it normal or its having issues of ignition timing?
Feb 5, 2021 at 10:50 AM
