missing, loss of power, hard to get it past fifty mph
1993 ISUZU TROOPER
133,000 MILES • 3.2L • 6 CYL • 4WD • MANUAL
STEINBECK
Went over a pass the other day and had to have the vehicle in third (pretty big pass between Idaho and Jackson Wyoming. Got gas at Sinclair station (ethanol free?) and returned home to Idaho. Next day engine was misfiring and did not want to go over fifty on a flat. after five miles pulled over checked plugs and wires. still bad backfiring. Bought new plugs (double platinum) installed, added Seafoam and again filled the tank. drove around awhile (half tank) let it sit a day. Three days later same problems. valve four has no engine change when wire is removed, but all coils are sparking. Help, I cannot afford a new beater.
Oct 29, 2017 at 12:18 PM
It sounds like you may have low compression causing the problem can you follow this guide and do a compression test please?
Oct 30, 2017 at 2:59 PM
