I have just replaced rings and bearings in my engine "4G63 Sirius with Turbo" and fitted it back into the car. The car was running at roughly 30 degrees BTDC before I pulled it apart. I discovered that when I put a timing light on it.
Putting it back together I adjusted everything according to the book. Firing order 1-3-4-2.
I have lined up my balance shaft in the engine. I lined the crank shaft, oil drive and cam shaft up with the marks on the engine. I believe my distributor is set on no 1 and my no 1 piston is up TDC.
Now it sounds like it is 2 gears not meshing up when I turn it over but it does not fire or even backfire
[img:3d6ccc004f]http://www.2carpros.com/forum/automotive_pictures/561696_Timing_1.jpg[/img:3d6ccc004f]
Aug 15, 2010 at 12:18 AM
