Driveshaft broke while driving?
1997 CHEVROLET 1500
190,000 MILES • 5.0L • 2WD • AUTOMATIC
SMITH EVON
I was driving and I heard a noise, like it was breaking underneath the truck. I came to an instant stop. And the bad tires locked up the dry shaft hanging. And I want to know is my dimension or something like that. Is bad
Aug 16, 2024 at 9:15 PM
SMITH EVON
My drive shaft broke.
Aug 16, 2024 at 9:39 PM
Thanks for the image, yep you have a broken driveline, but I would raise the rear of the truck to see if the rear wheels will turn. It could be the driveshaft broke due to the rear differential issue, here is a guide that can help:
Here is a guide to help with the U joint replacement:
https://www.2carpros.com/articles/how-to-replace-a-universal-u-joint
If the rear wheels turn, I would service, the differential. This video will show you how, and you can look for metal in the gear oil:
https://youtu.be/6F26Kir0OCg?si=hpH62tS8CnpEAffs
Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Aug 17, 2024 at 10:28 AM
