Grinding noise during small acceleration
2000 SUZUKI ZEN
8 MILES • 1.0L • 4 CYL • 2WD • MANUAL
MAHENDRA PARATE
While accelerate in cold start huge grinding noise coming from engine compartment. i removed the belts then start engine still grinding noise is coming. i changed my timing belt also but no change in sound. what i do now?
And engine is overheating in just fifteen minutes from cold start. no white smoke from exhaust and no milky color on engine oil cap.
Jan 27, 2018 at 1:57 AM
This sounds like you have two separate problems the first is the noise. I would check the starter motor because it sounds like the Bendix return spring has gone bad. Next on the overheating I would replace the thermostat to start and if you have done that is sounds like the water pump impeller has rotted or fallen off.
Here are some guides to help you:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
Jan 28, 2018 at 1:37 PM
