Navigation screen issues
2002 ACURA MDX
200,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
LEONARD JUL
My navigation screen in sometimes black and no lights on my transmission shift bar.
Feb 10, 2020 at 8:31 PM
JOETECHPRO
  • 705 POSTS
Hey LEONARD JUL,
Do any other interior lights not work when this fault occurs - Cruise control, hazard switch etc?
Any particular time that this happens?
Always on start up or is it random?
Do the lights come back on or do you have to cycle the ignition?
Regards, Joe
Feb 10, 2020 at 11:28 PM
LEONARD JUL
Hello Joe, Many thanks for your response. I addition the cruise control switch does not work and the AC rear control. also the sun visor light is not functional. The navigation system appears randomly without turning on the ignition. The light of the transmission shift bar never appears.
Feb 12, 2020 at 5:54 AM
JOETECHPRO
  • 705 POSTS
Hey LEONARD JUL,
Does the radio function okay and it is just the display cutting out?
I would first check the interior light fuse as explained in the fault diagnosis guide attached below.
Please can you remove the navigation display and check the power and ground to the unit when it is on and when the fault occurs?
Are you losing power?
The accessory circuit may be the problem.
Let us know how you go with these tests, any questions to clarify anything please do not hesitate to ask.
Regards, Joe
Feb 13, 2020 at 1:40 PM
