new oil pump wont bleed up
2008 CITROEN C4
74,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • AUTOMATIC
HANNAHWHITEHURST
  • 5 POSTS
Hi, I have the 1.6 hdi the engine has been fully reconditioned after blown turbo. the new oil pump is not pumping oil, it is still dry the new turbo is pumping oil to the head so there is no blocked passages from filter house up. please help, the oil pump is not an aftermarket one it is from the main dealers and I was told to plug and play no need to prime. thank you.
Sep 22, 2016 at 12:29 PM
Try removing the oil filter and pumping oil down through the main port, this will get the pump "wet" and begin the pumping action.
Please let us know what you find so it will help others.
Best, Ken
Sep 25, 2016 at 8:24 PM
HANNAHWHITEHURST
  • 5 POSTS
thank you for your help ken im waiting for an oil pressure gauge im sure there is a blockage somewhere maybe the oil cooler the engine has been stripped to bear block and cleaned im at the end of my teather now but ive spent too much on it to back out now there does seem to be more oil going to the head but the hydraulic lifters arnt happy which are also new the crazy thing is it was the turbo that was the problem now it seems to be the main oil supply to the head
Sep 29, 2016 at 12:20 AM
In the head gasket there is a passage that is meant to feed the turbo and lifters, if the wrong head gasket was used the oil to the top part of the engine will be a problem.
Sep 29, 2016 at 9:25 AM
HANNAHWHITEHURST
  • 5 POSTS
would it stop all oil to the top there is oil getting there from the turbo could there be a problem with the vacume pump causing blockage and knocking as if it was the lifters thank you
Sep 29, 2016 at 1:05 PM
It is hard to say there might be two oil passages. But if no oil is getting to the turbo and lifters it would be the first place I would look.
Sep 29, 2016 at 7:19 PM
HANNAHWHITEHURST
  • 5 POSTS
there does seem to be lots of oil getting to the head now is there anything i can do to bleed the lifters up thank you
Sep 30, 2016 at 3:06 AM
The valve train should bleed out on it own how long has the engine been running?
Sep 30, 2016 at 11:00 AM
HANNAHWHITEHURST
  • 5 POSTS
hi do you know how i can take the pressure sensor out without removing the alternator thank you
Oct 6, 2016 at 12:02 AM
I'm am sorry I do not can you send a pic of what you are talking about please?
Oct 6, 2016 at 9:23 AM
