Both side Brake Light always on even switch off the engine?
2015 NISSAN ROGUE
102,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
NIVIKAMAL
  • 4 POSTS
I have a weird issue that started a few days ago. Brake Light on both sides is always on even when I switch off the engine.
Read Top Center Brake Light working fine and only on when I press the brake.
So, I checked the Brake Light switch, and it is working based center brake is on when I pressed brake.
Do you think there could be ground issues with both sides of the brake lights?
Currently I can't get it through inspection due to always on lights.
When I checked with nearby service center and Dealer service center they said something with electrical issues.
Aug 17, 2023 at 4:36 PM
It sounds like the BCM has gone out. But to be sure, you can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change out the BCM, you can get a preprogrammed unit by searching Google or Ebay. Also, I have included the brake light wiring diagrams so you can see how the system works and which fuses to check just in case. Check out the images (below). Please let us know what happens.
Aug 18, 2023 at 11:16 AM
NIVIKAMAL
  • 4 POSTS
Thanks Ken L. I will take a look and update you.
Aug 18, 2023 at 11:30 AM
NIVIKAMAL
  • 4 POSTS
Hi ken,
I took two times for getting service for this issue (one with normal service company and 2nd dealer service) both did diagnostic, and they didn't tell anything about BCM. I will buy and diagnostic and see.
Aug 18, 2023 at 12:00 PM
Sounds good, a CAN scan should tell us something, please let me know.
Aug 19, 2023 at 9:31 AM
NIVIKAMAL
  • 4 POSTS
Dear Ken,
Here is the code I received from CAN:
P062F - Internal Control Module EEPROM
P0603 - Internal Control Module keep alive memory
Aug 20, 2023 at 7:06 AM
Here's a brief explanation of each code:
P062F - Internal Control Module EEPROM:
P0603 - Internal Control Module Keep Alive Memory:
I would go over all fuses in the vehicle with the systems on.
here is a guide to help:
If all fuses are good it sounds like the ECM is having a problem, you can get a preprogrammed unit by searching Google or Ebay.
Here is how to change the ECM out. Check out the images (below). Please let us know what happens.
Aug 21, 2023 at 9:17 AM
