1993 Nissan Sentra altenator will not charge battery
1993 NISSAN SENTRA
175,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVIDDLW
  • 39 POSTS
any help please,
i have a1993 nissan sentra xe car. the other day i notice that the batteryu would not stay charged. i had battery tested and it was a good battery, so i tried the only thing i know to test the altenator myself. i started car and remove one of the battery cables from the battery and the car cut off. i was told that my altenator could be bad because the car cut off when battery cable was removed. also i can jump car off cause i have ran battery down and car will run for 2 minutes or so and it will cut off and will not start again unless jumped off. i took altenator to a parts store to have tested and was told it was bad. being that i not intirely trust astore that s in business of making money when possible i took altenator to another parts store and they tested it 3 times and said it was a good altenator. does anyone have any suggestion on what could be wrong?
Aug 28, 2009 at 9:00 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Check fuesiable link form batt positive Gray on 1.6L blue on 2.0L. porbe with test light goes to white wire on alt term. if burnt then alt will not charge.
Thanks for donate
Aug 28, 2009 at 9:25 AM
