Have had several issues with truck starting. Timeline below. Tried starting several times each of these days.
8/24. no crank, no start, dash lights on. Thought it was starter so replaced starter but still didn't work. Replaced clutch rubber stopper and it worked.
8/25. no crank, no start, dash lights on. Battery cables were loose. Tightened and it started.
9/16. no crank, no start, NO dash lights. Replaced battery and it started.
9/24 - put original starter back in and ran fine with no issues.
10/13. drove 2 miles down the street. parked about 20 mins. No crank, no start, dash lights on. Battery and starter tested at AutoZone. Battery passed. Starter also passed but was causing an issue jamming the test machine. Bought a remanufactured starter and put the same battery back in. Still didn't start.
10/15. went back to look at it and started on the first attempt.
10/20.drove 15 miles round trip. no crank, no start, dash lights on. Disconnected and reconnected battery terminals. Started up.
10/25. drove around the neighborhood. Turned off and tried turning right back on. no crank, no start, dash lights on. Replaced terminal screws. Started up.
10/27.no crank, no start, dash lights on.
11/6. replaced battery terminal cables and still not working.
11/7. obdII scanner shows no codes. Battery voltage 11.8. Tried jumpstarting when battery was at 13.5 and no crank, no start, dash lights on.
Nov 10, 2023 at 12:06 PM
