Will not stay running
2002 MITSUBISHI MONTERO
200,430 MILES • 3.0L • 3 CYL • 2WD • AUTOMATIC
COURTNEY BAILEY
  • 20 POSTS
I have the vehicle listed above it is the Sport model. One day while I was driving the vehicle shut off. it would crank up but would not stay running. (had to be towed). but previously it was acting up days before like it was losing power. So we bought a fuel filter that did not did not help. tested the fuel pump it works but It is not getting fire back there. Any ideas? It will crank up but only stay running for a couple of seconds or sometimes until you give it gas. Could it be the fuel relay? Please help! Thanks.
Jan 3, 2018 at 1:18 PM
It does sounds like the fuel pump and I will find the location no problem. Can you double check the year please my information does not show a Montero in 2012?
Jan 4, 2018 at 3:50 PM
COURTNEY BAILEY
  • 20 POSTS
We checked the fuel pump it works by checking it direct, but we are not getting any fire back there to the fuel pump.
Jan 4, 2018 at 6:42 PM
COURTNEY BAILEY
  • 20 POSTS
Sorry the year model is 2002!
Jan 4, 2018 at 6:44 PM
COURTNEY BAILEY
  • 20 POSTS
It cannot be the fuel pump because it works, just not working in the back because there is not any power going to the fuel pump. But recently before it quit I had a programmed key that broke and I just taped my spare an the chip together. Was thinking could that be a possibility why it might not be getting power some sort of way back there to the fuel pump. Thanks
Jan 4, 2018 at 6:49 PM
Hi Courtney,
Yes, the chip can cause the issue. Is there a security light flashing when you try and start the car? Here is a wiring diagram of the fuel pump and engine to help us see what's going on.
I would check all system fuses here is a guide to help.
There is also a PCM relay that I would check as well.
Jan 5, 2018 at 11:51 AM
COURTNEY BAILEY
  • 20 POSTS
No the security light is not flashing. All the fuses seem to have power to them. They were all hot. A month before when we broke the key and tried the spare key the security light was flashing. But when we taped it around the spare key it crank right up and was driving it. However, weeks later it just shut off going down the road and now is not getting any fire to the fuel pump. Thanks for your time!
Jan 5, 2018 at 12:24 PM
This makes me think the PCM relay can be the culprit. Can you please test for power and check the relay operation?
Jan 5, 2018 at 12:30 PM
COURTNEY BAILEY
  • 20 POSTS
PCM fuse is hot .. an all the other fuses are too..
Jan 8, 2018 at 3:12 PM
COURTNEY BAILEY
  • 20 POSTS
My dad is saying that one wire coming off the fuel pump is hot but the other one isn't . Any other suggestions? Thanks for the help
Jan 8, 2018 at 9:58 PM
I would check fuse fL3 and f10 in the fuse panel also try and replacing the relay for the fuse pump. The locations are in the post above click the images below.
Jan 9, 2018 at 1:12 PM
COURTNEY BAILEY
  • 20 POSTS
A friend mentioned the knock sensor.. Could that be true. What's your opinion ?? Thanks
Feb 4, 2018 at 11:46 AM
If the crankshaft sensor has failed it will not turn the fuel pump on. Can you turn the engine over and check for spark?
Feb 5, 2018 at 10:41 AM
COURTNEY BAILEY
  • 20 POSTS
Thank you so much for your time
Mar 11, 2018 at 10:31 PM
No problem we are here to help, can you tell me if you got the problem fixed or?
Mar 12, 2018 at 11:34 AM
COURTNEY BAILEY
  • 20 POSTS
We fixed it .. It was the camshaft sensor..
Mar 12, 2018 at 9:02 PM
Nice work, we are here to help, please use 2CarPros anytime.
Mar 13, 2018 at 10:49 AM
