No power to ICM
2004 SATURN ION
150,000 MILES • 2.2L • 4 CYL
MICHAEL042
  • 4 POSTS
Getting no power to fire spark plugs. Got the constant twelve volt power going to ICM but not to spark plugs. Cranks over and has fuel. All fuses are good. Just has no to fire spark plugs. Changed ICM and coil pack.
May 22, 2018 at 12:15 PM
SATURNTECH9
  • 30,869 POSTS
It sounds like it could be the crankshaft position sensor. Do you have a multi-meter to do some testing?
May 22, 2018 at 7:08 PM
MICHAEL042
  • 4 POSTS
Thanks for getting back with me. I do not have that meter. However, that is not the problem. Could it be the ignition itself?
May 23, 2018 at 10:55 AM
SATURNTECH9
  • 30,869 POSTS
How do you know the crankshaft position sensor is not the problem? Also, you verified there is not spark while cranking the engine over?
May 23, 2018 at 11:28 AM
MICHAEL042
  • 4 POSTS
I replaced the sensor. Yes I have tried all that.
May 23, 2018 at 11:32 AM
SATURNTECH9
  • 30,869 POSTS
Have you checked to see if your setting any codes in the computer?
May 23, 2018 at 8:22 PM
MICHAEL042
  • 4 POSTS
No codes.
May 23, 2018 at 8:23 PM
Lets check the wiring for the system to confirm and if okay I believe the PCM has gone out. Here is a guide and the engine wiring diagrams to confirm the issue. Check power and grounds for the PCM.
May 26, 2018 at 11:41 AM
