Hi everyone, my truck cracked a radio on the plastic ends. Well, this is when the headache started because i know there's a cause for that. so, I replaced the radiator, changed the thermostat, new antifreeze, and belt. I started the truck up and noticed the fan was not kicking on. changed the coolant temperature sensor out with new harness because the old ones were corroded, still no fan. turn the A/C on and the fans worked, but when sitting at idle with no A/C the fan will not turn on checked the cabled/wires no damaged then i notice with the truck on if I disconnected the harness from the coolant temperature sensor the fan would turn on, but when i plug it back into sensor it doesn't work. I really need you guys help on this. Thanks
Jan 17, 2022 at 6:08 PM
