No spark or crank?
2005 KIA SEDONA
189,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
JASMINECLYBURN64
  • 5 POSTS
My car is not starting and there is no spark or crank. I had the battery changed out, fuel pump, coils changed, and new gaskets put on the van still nothing. What could be the reason it's not starting?
Dec 30, 2022 at 7:39 AM
So, is the engine craning over and not starting or the engine is not cranking over? Please check out this guide and get back to me:
Please go over this guide and report back.
Dec 30, 2022 at 1:52 PM
JASMINECLYBURN64
  • 5 POSTS
crank but won't start and no spark to the spark plugs.
Dec 30, 2022 at 2:18 PM
We should run the codes to see what comes up, but I have seen the crankshaft angle sensor go out which will not produce a trouble code.
Here is the location of the crankshaft angle sensor so you can check the electrical connections and replace the sensor. Also, I noticed this engine has a timing belt, can you crank the engine over and see if it sounds different to you, you can upload a short video of the engine cranking over I can tell for sure if the belt is okay or not. If the belt goes out it can take out the sensor wires. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Dec 31, 2022 at 1:10 PM
JASMINECLYBURN64
  • 5 POSTS
okay will do!
Dec 31, 2022 at 2:45 PM
JASMINECLYBURN64
  • 5 POSTS
The van has no codes coming up. But here is the video that was requested. Please let me know what I really need to do because my car is for work.
Dec 31, 2022 at 2:59 PM
JASMINECLYBURN64
  • 5 POSTS
Also, the crankshaft was replaced with a new one.
Dec 31, 2022 at 3:00 PM
Thanks for the video, I heard the fireworks going off, happy new year! The engine sounds good so mechanically you don't have a problem there. Can we check for spark here is a video to help you.
https://youtu.be/baq_aEWNQ0Y
Let me know what you find.
Dec 31, 2022 at 5:57 PM
