I bought the car with a broken odometer and shortly after the cruise control went out. The CEL went on and it is a 0500 code-speed sensor. I removed the vss and it reads 280 ohm across the contacts and the voltage goes up and down accordingly. I replaced the instrument cluster with one from a junkyard and the odometer still doesn't work. The vss signal wire works and reports fine at the ECM. I'm not sure what else to check/fix.
Dec 21, 2014 at 2:04 PM
