Oil leak not by the valve gasket it was coming from the exhaust manifold?
2011 MAZDA 3
176,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
RR23ANGEL
Just recently changed the valve cover gasket to my car and just noticed that the oil was still leaking but it was not by the valve gasket it was coming from the exhaust manifold so I loosed it up an oil started to run down the back of engine. What does that mean blow gasket, or worse a crack head ?
May 7, 2023 at 11:49 PM
If you have oil leaking from the exhaust manifold, it may indicate a problem with the gasket or with the manifold itself. It's possible that the gasket wasn't properly installed when you changed the valve cover gasket and now it's causing oil to leak from the exhaust manifold.
If you loosened the exhaust manifold and oil started to run down the back of the engine, that could indicate a more serious issue such as a cracked head or a blown head gasket. A cracked head or blown head gasket can cause oil to leak into the combustion chamber, where it is burned and exits through the exhaust system.
May 8, 2023 at 4:32 PM
