Where is the oil pressure sensor location?
2011 VOLKSWAGEN JETTA
10,000 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
STRATTON.M23
  • 20 POSTS
I need to replace my oil pressure sensor and I cannot find its location. I have tried looking online with no luck. If anyone can tell me where it is and the procedure to replace it, I would really appreciate it. It is a pzev engine.
Feb 4, 2022 at 7:41 AM
It's behind the alternator, below the intake, at the rear of the engine. See pic 1. In pic 2, I highlighted two connectors. Number 1 is the oil pressure switch and number 2 are the reduced oil pressure sensor. Number 1 will be blue, and number 2 is brown.
As far as replacement, simply disconnect the electrical connector and the sensor (using a deep well socket) will screw out.
I added pic 3 so you could get a better view of what the sensor looks like.
Let me know if this helps.
See pics below.
Feb 4, 2022 at 8:48 PM
STRATTON.M23
  • 20 POSTS
Is it easier to access from underneath the car or above? And will I need to remove anything to access the sensor?
Feb 5, 2022 at 3:26 AM
If you have a lift to place the vehicle on, you will need to remove the splash shield from under the vehicle, but it should be easier.
Let me know how things work out for you.
Feb 5, 2022 at 12:19 PM
STRATTON.M23
  • 20 POSTS
Thank you for the help. A little background to my situation, the low oil pressure light comes on intermittently when driving at low speeds, so I wanted to change the sensor to see if that is the issue. Oil was recently changed, and is still clean, and no abnormal sounds coming from the engine. I'm new to VW'ss, so my question is what is the difference between the oil pressure switch and the low oil pressure sensor? And should I replace both of them at the same time. My mechanic is going to try to work on it this week and he hasn't worked on a VW, so I'm trying to get him as much info as possible.
Feb 7, 2022 at 4:39 AM
The oil pressure switch is nothing more than a toggle switch that will turn a light on if a specific pressure is reached. (Too high or low). A sensor provides a digital signal which you measure (in this case) specific pressures and doesn't toggle on or off.
Just for curiosity, did this happen after a recent oil change? I have seen the filter collapse and cause the flickering light at low RPMs.
One good thing is there are no sounds coming from the engine. That is usually a good indicator that it is a sensor issue and not an internal engine issue.
Let me know if I can help.
Feb 7, 2022 at 6:34 PM
STRATTON.M23
  • 20 POSTS
Yes, I just got my oil changed at a shop at the end of December. It's one of those roll in and out oil shops. I talked to my mechanic, and we are going to check out the oil filter first and replace it if necessary. I will let you know how it goes.
Feb 8, 2022 at 10:04 AM
Sounds good. Let me know what you find. I hope it's something that simple for you.
Feb 8, 2022 at 2:57 PM
STRATTON.M23
  • 20 POSTS
Sorry it took so long to update, but he checked the filter first and it was crushed. So far that seems to have resolved the issue. He did notice some condensation in the oil, so he completely changed the oil and cleaned up what he could. Some of it resembled water but had the smell of gas. With my oil light coming on, I didn't let my car warm up long before heading to work. Could that cause condensation? It has also been below freezing in my location.
Feb 24, 2022 at 11:55 AM
Absolutely that can cause condensation. When the engine is hot and you turn it off allowing it to cool, that is when it happens. Just like when you see the white steam from the exhaust on a cold morning evaporating from the exhaust.
I'm glad to know it's taken care of. Also, don't worry about the late reply whatsoever. I'm glad to hear it's fixed and am certain your reply will help others.
Take care and feel free to come back anytime in the future. You are always welcome here.
Feb 24, 2022 at 6:45 PM
STRATTON.M23
  • 20 POSTS
I have an update on my situation. My oil pressure light just started coming on again. I have read that the oil pickup tube filter could be clogging up on me. Could this be causing the issue?
Mar 7, 2022 at 5:43 AM
There is a pickup tube/screen that can cause low or no pressure. However, that is usually the result of not changing the oil and it being really dirty internally.
Has the vehicle been serviced regularly?
Mar 7, 2022 at 6:41 AM
STRATTON.M23
  • 20 POSTS
Yes, the oil and filter were changed a couple of weeks ago. Is there any other things I can check before the pickup tube?
Mar 7, 2022 at 7:11 AM
STRATTON.M23
  • 20 POSTS
I have only had the vehicle less than a year and the Carfax only showed minimal on the types of service done, but it did seem to have regular servicing recorded.
Mar 7, 2022 at 7:13 AM
Open up the oil filler cap on the valve cover (where oil is added). Take a flashlight and look down inside to see if it looks like burnt oil or sludge.
Mar 7, 2022 at 1:19 PM
STRATTON.M23
  • 20 POSTS
Will do. we had the valve cover off a few weeks ago and there was a lot of condensation in there, so that's when we changed the oil and filter.
Mar 7, 2022 at 1:33 PM
Also, make sure the PCV or according to VW (crankshaft housing vent) isn't plugged and isn't restricted.
Let me know what you find. Also, let me know how much condensation was found under the valve cover.
See pic below for PCV hose location.
Mar 7, 2022 at 4:36 PM
STRATTON.M23
  • 20 POSTS
Will do, I had read an article online talking about the PCV valve and I ordered a new one yesterday, just to be safe. The article had mentioned that sometimes the diaphragm inside tears cause condensation to form. I will check it to see if there are any clogs as well. And i will see if my mechanic still has the picture from under the valve cover before he cleaned it.
Mar 8, 2022 at 4:41 AM
That's a good idea. Let me know if it helps. I will watch for a pic of what was found.
Mar 8, 2022 at 1:20 PM
ALEXANDER CRUZ
  • 5 POSTS
even with all above information i still cannot find where to install the oil pressure sensor on my 2008 rabbit 2.5l manual transmission.
Oct 8, 2024 at 7:21 PM
this post is for a 2011 VOLKSWAGEN JETTA, so this is why, please post your new question here, you must be logged in.
Oct 9, 2024 at 10:04 AM
