Error Code P0113
2002 OLDSMOBILE ALERO
STEPH108
I got the error code P0113. I've already changed the IAT Sensor. How do I fix this?
May 22, 2010 at 12:39 PM
This code is in fact for the Intake air temperature sensor, however there are a couple things that can cause this. So clearly the sensor was not the issue.
So, let's check this code and find out what turns up. Here are a couple of guides that will help with this:
Below you will find the testing from the manual that will help with this. Let me know what questions you have with this and what you find when you run through the testing.
Thanks
Apr 6, 2022 at 5:51 PM
