Turn signal not working
2004 OLDSMOBILE ALERO
MLD1983
When I flick the turn signal switch sometimes the light on the dashboard comes on and sometimes it comes on for a bit then cuts off. Other times it doesn't come on at all. Is this a bulb problem or something else?
Dec 10, 2009 at 1:24 PM
THIOTT
it is solder joint cracking caused by rapid temp transitions. causes a open circuit and signals/hazard become intermittent and/or inoperative
dealer will replace the switch.
Apr 16, 2019 at 6:33 PM
THIOTT
While driving my car there is a random turn signal sound coming from the dash. We have removed the vent and have accessed the hazard switch. If this is removed, we do not hear any sound, however the turn signals fail to work. Periodically you can hear a sound that is reminiscent of an electrical short. we thought it could be the hazard switch that was bad but have purchased a used one and the sound continues. Is it possible that the turn signal/head light switch can be the part that is going bad?
Jun 26, 2020 at 12:00 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
may be a loose / weak ground wire at the switch causing the issue. inspect wiring to the signal switch and hazard switch, if all wiring is OK then signal switch may be at fault.
SARNOLD2426
I have just replaced the hazard switch in it. Now the turn signals will not come on. I have also replace the turn signal controller due to the wiper control arm was broken. So any help would be helpful.
Jun 26, 2020 at 12:01 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Have you checked the fuse for the turn signals?
Are the hazard lights working?
SARNOLD2426
After replacing everything, I later learned that the turn signals have not been working for the past few days prior of me replacing everything. Yes I did check all the fuses and everything check out okay. Also, the hazard switch is working as well. So at this point I am leaning towards that there is a short somewhere in wiring.
There is a auto park lamp control relay that looks like it controls the power to the turn signals that could be out, here is a guide and a diagram that can help you get the problem fixed. Also you can check for power and see if you are loosing it somewhere.
and
Please run this test and get back to us so we can continue helping you.
Best, Ken
MARREY61
2004 Oldsmobile Alero 4 cyl 34000 miles
how do you fix the drivers back blinkers
Jun 26, 2020 at 12:02 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
Hi there,
Depending on what the fault is, have you check the globe, power at the socket and the earth, these are the main reasons for a light failure, start here.
mark (mhpautos)
MALACY0349
For a while the turn signals would work but one day it stopped working the majority of the time.
Now the turn signals have become irregular in their functioning. Some times they will not come on, other times they will work like they are supposed to and even weirder is quite often a solid hit on the dashboard right above the gauges will bring them back on.
Any ideas?
Jun 26, 2020 at 12:47 PM (Merged)
HMAC300
  • 48,601 POSTS
it might be a loose connection at dash, or it jars the hazard switch where your flasher is .or coincidental
ANNE4670
We have a problem with the turn signal not working at different times (when it is raining or the air conditioner is on and it causes moisture). My husband has checked a few things , but still we would like more advice on how to fix it so we don't have to stick our arm out the window. Can you give a suggestion on what to try?
When it doesn't work, do you mean it doesn't flash or doesn't work at all?
ANNE4670
our turn signal does not work at all at iffeerent times
If they don't work at all, I would start at the switch in the steering column.
SNUPCAKE
I have a 2003 olds alero w 76k miles. Just recently the following things have started happening. The turn signal goes ticka-ticka-ticka when it should shut off. the blower is not working well, it only works on high, and the lighter/outlet thing doesn't work if I plug anything in. Is this a sign that something big is going on or are these little unrelated things.
HMAC300
  • 48,601 POSTS
they could be unrelated. check your fuses for the lighter and body to battery ground for the flasher. you could have a bad flasher as well. for the blower check your resistor, it should be by the blower, see if it is getting and putting power out, it may not be. if it's not getting power check the control head.
If the signals are not canceling, chances are the plastic tab that shuts them off when the steering wheel centers is broken. If the blower motor only works on high, chance are either you have a bad blower motor resister or relay. Finally, check for a blown fuse to the lighter. Check to see if there is power to the lighter. There should only be one wire going to it.
TWINKIEDELIGHT05
  • 14 POSTS
when you go to turn on the blinker sometimes they dont' work. but if they don't come on an you turn the fourways on an leave them on while you turn the blinker on an then turn four ways off the blinker will blink. but for some reason now that even though the blinker isn't on the ticking noise that the blinker makes while blinking ticks as if the blinker is on an it isn't. any solutions
Jun 26, 2020 at 12:48 PM (Merged)
FIXITMR
  • 9,990 POSTS
try lubing hazzard switch. it interacts with turn signals.or just replace it? you also may have a bad multi sitch which is your turn signal assembly. could be wire loose or bent contact, etc.
SIMON10
If you haven't already got the issue fixed, try calling a gm service tech and provide them with your vin number. I have a 2000 that did the same thing and it was recalled so they fixed it for free. It has something to do with bad soldering.
LOGANB13
When you start the car the blinker works but when you put the car in drive and start driving it stops working.
Jul 17, 2020 at 4:23 PM (Merged)
STEVE W.
  • 15,113 POSTS
All blinkers or just one? Do they work in reverse? Neutral? Do the hazard flashers work in drive?
ASHWOME
My blinker works when it wants too, should i pay $200-$400 to get the wiring fixed or is this a simple fix that i can do?
Jul 17, 2020 at 4:33 PM (Merged)
KNOWYOURAUTO
  • 113 POSTS
ashwome,
Has an inspection been performed that found a wiring problem? If that is a shops diagnosis, ok; however, the common failure for this problem is the turn signal/hazard flasher mounted in the center of your dashboard.
Next time your turn signals don't activate try rapping firmly near the hazard button, preferably above it without actually touching the switch. The relay contacts often fail and may reconnect from the bumping. If this is symptom, I recommend taking it to a dealer that has performed this repair before. Removing the center vent and two 7mm screws is difficult without damaging either component.
Regards,
KnowYourAuto
SUGAREE53
  • 7 POSTS
sometimes it works sometimes it doesnt
Jul 17, 2020 at 4:35 PM (Merged)
When it doesn't work, do any of the lights come on?
SUGAREE53
  • 7 POSTS
no inside turn signal lights come on or outside either
It sounds like the switch itself is bad. I would check that first.
SUGAREE53
  • 7 POSTS
sometimes I hear a buzzing sound when I turn on signal light and it doesnt work
Is the buzzing coming from the switch or under the dash?
SUGAREE53
  • 7 POSTS
the dash i think
Try replacing the flasher. It could be the problem.
SUGAREE53
  • 7 POSTS
thanks jacoband nickolas for your quick response
Let me know what you find. The flasher is a cheap part.
