1997 Oldsmobile LSS no check engine light
1997 OLDSMOBILE LSS
168,000 MILES • 6 CYL • FWD • AUTOMATIC
OLDSMOBILE97LSS
starter cranked slow when engine was warm, I had to jump it a couple of times,the last time it started then died. I replaced the battery stillno crank,then Ireplaced the starter, still no crank. Then I replaced the ignition switch, still no crank. I then tried to read the codes, the code reader said no communication.
Nov 3, 2010 at 1:28 PM
JDL
  • 16,098 POSTS
Pin 16 at the datalink connector should be hot all the time, is it? If no voltage, check the fuse, rdo--cluster--misc fuse, 10 amp in the fuse box. My info shows a security system on your vehicle, I probably can't track that from here.
The purple wire at the starter solenoid S terminal, should be hot with the key in the crank position, if it isn't hot, backtrack the circuit. Any testing make sure the tranny is in park or neutral and the e-brake is set.
Nov 3, 2010 at 3:21 PM
