would any one know where the connecter for the O2 sensor is, i have a new sensor but where is the connecter located. any help please.
Feb 28, 2006 at 1:47 PM
JPAM
CERTIFIED EXPERT
UNDER HOOD, CENTER, LOWER ENGINE AREA, PASSENGER SIDE REAR OF ENGINE, MOUNTED IN EXHAUST MANIFOLD
Feb 28, 2006 at 1:58 PM
RICHP43
MEMBER
Maybe i should clarify- i need to know where the connector for the O2 sensor, coming from the ECU, and thanks for the info.
Feb 28, 2006 at 2:21 PM
MECHANIC116
MEMBER
Locate the 02 sensor, then follow the wire. The connector shouldn't be more than 12" from the sensor itself. (typically)
Feb 28, 2006 at 2:39 PM
RICHP43
MEMBER
Thats the whole thing i cant find the end coming from the module
Feb 28, 2006 at 2:43 PM
MECHANIC116
MEMBER
? lol....that makes no sense...are you saying it's endless? Locate the oxygen sensor...follow the wire that comes out of it until you find the connector. Don't just stop and give up if the wire goes through the firewall or into a wire loom.
