Overheating
2006 KIA SPORTAGE
137,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
SKYFIRE
Hi Team,
Have changed timing belt, water pump, radiator, coolant, thermostat, engine oil (5W30). Fluids have good levels.
No water in the engine oil nor oil into the coolant reservoir tank.
Car is working normally. No power loss at all.
Current outside Max Temp 35C.
Temperature running normally and as soon as switch on the A/C temperature goes up til reaching the red mark.
Same scenario when turning on inside heater.
By the when turning on the A/C, cooling fan is working too. Not sure about 2nd speed? Don't know how to test.
A/C is blowing cold air.
Fuse for cond 1 and cond 2 are okay.
Any lights on this issue?
Thank you.
Wishing you a nice day.
Best regards,
Gilles
Jan 13, 2020 at 4:24 AM
SCGRANTURISMO
  • 4,897 POSTS
As I was researching your vehicle's problem a came across this. It is a Technical Service Bulliten [TSB] for your vehicle for a re-flash of your vehicle's Engine Control Unit [ECU] for heater performance in cold weather. I have included for you in the diagrams down below. I would recommend calling your local dealership and talking to the service manager. You should be able to get this fixed under warranty. I hope this helps, and let us know how everything is progressing, please.
Thanks,
Alex
2CarPros
Jan 13, 2020 at 7:32 AM
SKYFIRE
Dear SCGRANTURISMO,
Thank you for your views/lights. ;)
Just wanted to clarify further car more accurate specs :
Nnitial entry into service: 26/01/2005
Diesel 2.0L
VIN : KNEJE55185K024476
TYPE: JE5518
Country current summer max Temperature : 35°C / 95°F
Based on those complementary info, are we still looking for ECU re-flash?
For my reference, could you please tell me why would the local dealership would bear this ECU re-flash into warranty?
Thank you very much for your assistance. :)
Jan 13, 2020 at 2:23 PM
SCGRANTURISMO
  • 4,897 POSTS
Yes. If it is covered under this Technical Service Bulletin, they should cover this at no charge. You will need to contact your local dealership's service manager and discuss it with him. Please keep us informed.
Thanks,
Alex
2CarPros
Jan 13, 2020 at 10:12 PM
SKYFIRE
Hi Alex,
You were right, the car ECU had a problem.
To reset it, I have unplugged the battery for 1 day, and re-plugged it and problem disappeared completely.
Thank you for your help on this.
Thanks,
Gilles
Feb 18, 2020 at 1:59 PM
SCGRANTURISMO is one of our best! please use 2CarPros anytime we are here to help.
Can you please leave us a rating? (copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
that would be great!
Feb 22, 2020 at 11:46 AM
