Code P0300 and engine running rough after replacing the timing chain?
2007 CHEVROLET SILVERADO
200,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
CASEY0714
  • 4 POSTS
I just replaced the timing chain on my truck listed above after replacing the timing chain. I now have a fault code P0300. I’m pretty sure that I installed everything correctly. But now I have the fault codes, and the engine is running very rough. Is it possible that the timing marks are not lined up correctly and maybe be off by a tooth?
Mar 4, 2025 at 10:02 AM
CASEY0714
  • 4 POSTS
I also replaced the plugs and plug wires. And I checked all of the grounds. I cleaned my throttle body, and I cleaned the mass airflow sensor.
Mar 4, 2025 at 10:17 AM
Yes, if you are off a tooth on the timing chain it will not run correctly. Here is a video of the job being done so you can compare what you did to see if it is correct:
https://youtu.be/mrp9YXPaYFg?si=p0yGPJJ2jmkl61BC
Please check the image below as well, Also, this can be a vacuum leak so I would go over this guide as well:
Mar 4, 2025 at 1:57 PM
CASEY0714
  • 4 POSTS
Thank you for the reply. I pulled the timing cover and checked. I was a tooth off. I got it lined up correctly. I also replaced all 8 coil packs. I am still getting the P0300 code, and the engine is running rough. Any suggestions on what to check next?
Mar 11, 2025 at 9:04 AM
Lets do a compression test to see if the engine is in good shape with no bent valves. You can rent a compression gauge for free at the auto parts store FYI.
Mar 11, 2025 at 12:42 PM
CASEY0714
  • 4 POSTS
Thank you for your support. I will do the compression test. I have a compression gauge. I will let you know what happens. Again, thank you so much.
Mar 11, 2025 at 1:35 PM
np, we like helping people :)
Mar 12, 2025 at 9:53 AM
