P0720 code with no speedometer or cruise
1996 DODGE STRATUS
150,000 MILES • 2.4L • 4 CYL • FWD • AUTOMATIC
JAMES PTACNIK
I have a P0720 code and non working speedometer on my car since buying it. I pulled the instrument cluster and repaired the notorious "cold solder" on the back that fixed the tachometer, but still have the code and no speedometer. I have also noticed cruise will turn on but not engage, most likely due to speedometer reading "0". I replaced the output speed sensor for the P0720 "Output speed sensor circuit malfunction", which made sense, but did not fix anything. I then replaced the input speed sensor since some people claimed this had fixed their P0720. I took car for a drive and not only did it not fix anything at all, but the transmission would not shift. I put the old input sensor back in and transmission shifts, but original issues still exist. I do not have the information to check the harnesses, not to mention getting down to the connectors with testers will be a challenge. I do not know if the cluster is still an issue, or if wiring/computer is faulty. Maybe try another new input sensor?
Jun 3, 2017 at 7:07 PM
I would try a factory vehicle speed sensor first then I would start checking the wiring. Here is a guide and some wiring diagrams to help you get the problem fixed.
Please run some tests and get back to us so we can continue helping you.
Jun 6, 2017 at 2:25 PM
