Codes P1768 and 0700
1996 CHRYSLER LHS
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
MIKE STEW2
What do these codes mean?
Aug 15, 2018 at 3:38 PM
CARADIODOC
  • 34,308 POSTS
P0700 - Transmission Control System Malfunction
P1768 - Automatic Transaxle
Code 700 is in the engine computer. It just means there is a fault code that needs to be read in the transmission computer. That is done because the defect can put the transmission into "limp" mode which keeps it in second gear. That increases fuel consumption, which increases emissions. Anything that could adversely affect emissions must turn on the check engine light, and that is the job of the engine computer.
You can go here to see the code definitions:
https://www.2carpros.com/trouble_codes/obd2/p1700
That is about the sorriest definition I have ever seen for the second code, however, you will see the number is highlighted in blue. Click on that to go to a list of posts with similar problems. Most of these fault code numbers are generic and are not specific to just your model, so look at some of the other posts on that page.
Aug 15, 2018 at 10:17 PM
