Engine coolant temperature problem, The water temperature is normal, but in cluster fluctuates ecu?
Apr 3, 2016 at 8:51 AM
CERTIFIED EXPERT
This sounds like a problem with the coolant sensor, this will make the temp gauge act erratic.
Best, Ken
Apr 23, 2016 at 8:30 AM
MEHDI_SHARIATI
MEMBER
but.temp coolant in diag is normal
Apr 23, 2016 at 10:17 PM
CERTIFIED EXPERT
Okay, if in diagnostics its normal then the gauge itself must be bad. I don't think its the computer because they rarely go bad, its more likely the gauge.
Apr 24, 2016 at 7:41 AM
MEHDI_SHARIATI
MEMBER
Electric thermostat temperature is -40
Apr 26, 2016 at 11:16 AM
HMAC300
CERTIFIED EXPERT
we have no info on how to check this car as it's not in USA have the sensor and gauges checked.
