Engine Mechanical problem
1963 Other Peugeot Models 4 cyl Front Wheel Drive Manual
Hello:
I am fixing an old peugeot 404, year 1963, 4 cylinders, 1700 cc. I took apart the engine, change the following items with new ones: pistons, rings, liners, valves (all), spark plugs, carburetor, distributor, spark plug's wire, head gasket, clutch, ...
After fixing the engine, putting it back with the car, after several checks of tuning, the engine ran.
Here is the problem that I can't solve: after running for about 5 to 6 minutes, the engine produces a blue smoke, smelling gasoline uncombusted. I check the bottom of spark plugs and find black ashes thicker and thicker if I leave the car running long time. So I start to clean up the plugs and the same thing happens again.
My guess is about the valves, but I am not sure. Anyway I don't have any apparatus to checks even the pressure. My only tools are screw drivers, wrenches and a galvanometer.
Could you help me out?
Thank you Sam
Hello:
Thank you Sam
Oct 10, 2008 at 2:31 PM
