1988 Pontiac 6000 not sure how to adjust timing
1988 PONTIAC 6000
200,000 MILES • 6 CYL • FWD • AUTOMATIC
MATTY118
car has a v6 with a distibutorless type ignition,someone removed what would have been the distributor to install a new seal.but since it does not have a distributor i dont see how this could cause the timing to be out as the shaft that is there as far as i understand is only used to drive the oil pump.however after changing all the coil packs new plugs and wires it still runs rough and has a miss.any help would be greatly appreciated.
Jan 29, 2008 at 1:31 PM
MIKEL
  • 8 POSTS
I don't believe you CAN adjust the timing on a DIS V6... it's all done by the computer. As far as what would cause it, it's hard to say without more information... it could be your timing belt/chain, or a spark problem, or a compression problem, or vacuum leaks.
Any other info you can share?
Feb 25, 2008 at 8:36 PM
