1998 Pontiac Bonneville HOW TO REMOVE DRIVER DOOR PANEL
1998 PONTIAC BONNEVILLE
60,000 MILES • 6 CYL • FWD • AUTOMATIC
WALT BOROSKI
MEMBER
1 POST
FOLLOW
ELECTRIC WINDOW ISN'T WORKING ON DRIVER SIDE, HOW TO REMOVE PANEL..
Mar 17, 2008 at 1:53 PM
RHALL77
CERTIFIED EXPERT
the panel is pretty easy to remove. Just make sure when you do it take a look and see what style it is. some you pull out and some you have to lift up. dont pull out on the ones that you lift on other wise you will break the tabs off. You should be able to pull it out a little and see what style it is.
