1984 Pontiac Fiero Fixing my brakes
1984 PONTIAC FIERO
170,000 MILES • 4 CYL • 2WD • MANUAL
KENNY MOBERLY
i have a problem with my brakes. my half shaft broke and so i took the caliper off the rotor and my little sister got in it one day and while the caliper was off she pushed the brake pedal a buch of times. so now my brakes are pushed against each other and i cant get them apart. how do i get them apart?
Jul 1, 2008 at 3:21 PM
MMPRINCE4000
  • 8,548 POSTS
You will probably have to remove the hydraulic line and see if you can push the piston back by hand.
Jul 9, 2008 at 6:22 AM
DAVIDBR13
  • 6 POSTS
[quote:c7a22f9418="mmprince4000"]You will probably have to remove the hydraulic line and see if you can push the piston back by hand.[/quote:c7a22f9418]
Yes, you will need to release the pressure before you can force them apart. After the pressure is relieved, it should be relatively easy to do. Be sure to bleed the brakes after everything is back together.
Sep 9, 2008 at 2:49 PM
