1985 Pontiac Fiero can not shift in any gear.while car is r
1985 PONTIAC FIERO
HO
Transmission problem
1985 Pontiac Fiero 4 cyl Two Wheel Drive Manual alot miles
ichange master cly. cluch slave.and the preasure plate bearring.and diss put it to geather and same result if i put it in gear and start it push the clutch it will go a head need help bad in the bahamas
Aug 26, 2008 at 7:06 PM
MMPRINCE4000
  • 8,548 POSTS
Make sure the MC is full of fluid and then bleed the slave cylinder.
Check the clutch arm to make sure it is tight and not cracked.
When you install the clutch master cylinder the "loop" that connects to the pedal must be pointing up.
Sep 1, 2008 at 8:24 AM
BUDDYCRAIGG
  • 2,262 POSTS
the clutch pedal could also be bent.
Dec 7, 2008 at 9:45 PM
