Engine Mechanical problem
1986 Pontiac Fiero 4 cyl Two Wheel Drive Manual 0 newm miles
Where do i begin to change fuel pump is it under the car , do i have to drop the tank, or is there a trick cause i cant find the gas tank its a new motor in the car and i think that the pump was never hook up i can spray the throttle body with starter fluid and it will crank the pump isnt working at all i removed the fuel filter and turn the key on and get nothing i guess what i need is where the fuel pump is located and where is the harness located
Dec 2, 2008 at 1:48 AM
