1995 Pontiac Firebird Smoke and Oil Leak
1995 PONTIAC FIREBIRD
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
JORDANF563
Recently I drove my Firebird for about 3 hours and about half way when I pulled to a light I noticed smoke coming from under the hood and out the passenger side from under the car. I pulled off to check and discovered that it was oil leaking on top of the catalytic converter and exhaust pipe. I check the oil and it had plenty in it so it is a slow leak that seems to only smoke when the exhaust pipe is hot. Could yall please tell me what is leaking because I recently had a o-ring inside the engine replaced and it still seems to leak? Thank you
Oct 30, 2008 at 8:03 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will need to wash it dawn and check for fresh leaks after a drive, check rocker covers as they often leak, if unsure return it to who did the work and get them to re check for a problem with the work they did. start here.
mark(mhpautos)
Oct 30, 2008 at 8:16 PM
