For the past 30,000 miles the front right disc brake pads wear down in 6000 to 10000 miles. I have replaced the rotors sevaral times, including the current pair which were an aftermarket high performance set of rotors. I even tried EBC's green pads, they lasted only 4000 miles. I finally replaced the both front calipers, about a month ago. The rotors were istill n good shape. I figured maybe I had either a dragging caliper or a gummed up caliper. The situation does not appear to have improved. I can tell from the brake noise that the right front disc brake pads, that it is wearing rapidly, again. What is the next area that I should look at, replace? Master cylinder, ABS valving? Thanks for your assistance.
Dec 21, 2007 at 9:27 AM
