I have had a problem with not getting any heat unless the engine is above 1000 rpms then when i let it back to idle again the heat cools off. also when the car first warms up it heats up to like 240 degrees Fahrenheit and and then will drop down to 200 which is the normal operating temp. Then i get great heat. I just replace the thermostat and water pump to try to solve this problem but no luck yet.I did notice what sometimes when i was bringing the rpm up using the throttle cable under the hood the lower radiator hose will collapse. Can anyone help me?
Nov 10, 2008 at 5:15 PM
