95 Grand Prix 3.1 SE ABS and Brake light On
1995 PONTIAC GRAND PRIX
GV77
  • 5 POSTS
I have a 1995 Grand Prix SE 3.1 with 153000 miles on it and about a month and a half ago i replaced the alternator and brake pads and i also turned the rotars. Around that same time my ABS light was going on and off. After i finished replacing all of that i noticed that my ABS light just stayed on and its been on ever since. Now, just recently my brake light has gone from going on about every other time i turn on the car to every time. My brakes seem to work fine? I was just wondering what the problem/s could be? Any advice would be gretly appreciated. Thank you.
Greg
Jul 26, 2007 at 6:51 PM
GV77
  • 5 POSTS
anyone?
Jul 27, 2007 at 7:37 PM
HARDMAN618
Hey bud, I had the same problem for awhile with the ABS light flicking on and off and my friend suggested to me that I check the brake fluid. I refilled it and the light went off and has been off since. Hope this helps.
Cory
Aug 6, 2007 at 11:43 AM
GV77
  • 5 POSTS
Thanks for the suggestion, but thats one of the first things I tried.. I also took it to autozone to run codes but my car is a year too old for that... Anyone else got anything?
Aug 6, 2007 at 3:53 PM
MERLIN2021
  • 17,250 POSTS
If you turned the rotors, you may have a buildup of steel shavings on you sensors. They are magnetic. try cleaning the sensors with compressed air. While your at it clean the ring gears too.
Aug 15, 2007 at 6:18 PM
GV77
  • 5 POSTS
ok will do..thanks for the advice...
Aug 18, 2007 at 6:22 AM
