Engine Cooling problem
1967 Pontiac GTO V8 Automatic lots miles
7 months ago I replaced the fan clutch and the engine was running at a pretty consistent 150 degrees. Then it sat for a few months and even had a trip to the body shop. Now the temp indications I am seeing are all over the place (but never zero). I'm not hearing any knocking like I would expect if it was a bad water pump. And the engine seems to be running smoothly. The strangest indication is sometimes when I throw it into neutral the temp will instantaneously drop from 250+ back to 150. The radiator level is dropping slightly as well so I am guessing it is getting hot.
Should I look at a temp gauge or is it possibly a wiring problem.
Nov 10, 2008 at 1:19 PM
