Leaking antifreeze from front of engine. Is there a bypass hose on this SOHC engine or can it only be from the waterpump?
Jan 9, 2006 at 7:48 PM
2CARPRO JACK
CERTIFIED EXPERT
look below the pump and see
Jan 10, 2006 at 5:51 PM
SPADE007
MEMBER
[quote:b8c05d52f1="stevelutz425"]Leaking antifreeze from front of engine. Is there a bypass hose on this SOHC engine or can it only be from the waterpump?[/quote:b8c05d52f1] if its leaking at the bottom of timing belt cover it is your water pump
