not sure what category this question is under !! Engine runs fine - after 5 minutes or so the ses light comes on and the cooling fans start running - shut the engine down - restart - and although the engine is warm the process pretty much repeats itself - I was getting an egr electrical code 27 - replaced the egr solenoid and it did not help - the scanner now says no trouble codes - I have not owned the car long - I believe the engine ran louder when it first started prior to having this issue - not so much the engine but perhaps something auxilary to the engine - I also replaced the temperaure sensor - the engine does not run hot - I'm not a mechanic in any sense - I do try to fix things on my own - any help is appreciated - thanks
Oct 26, 2009 at 10:38 AM
